Vinly Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2005, 01:39 PM   #1
vinly siding
how much would i be looking at if i wanted to get my house done in vinyl siding, its a small house like only 800sqf.i would like it to go over the wood siding.
this old house is offline   Reply With Quote
Old 11-29-2005, 02:13 PM   #2
Siding wise 800sq ft has nothing to do with sq area of each wall. Recalculate and take to some local vinyl siders.
JustaFramer is offline   Reply With Quote
Old 11-29-2005, 04:40 PM   #3
Smile
vinyl siding
Don't know your area, but here (ks) we would figure it at average of $350 per sq. That would include the siding and trim accessories, vinyl soffit, wrap window/door trim and fascia with aluminum coil stock. Also would include 1/4" foam backer-board. This wouild be total job, labor and all.
tedn332 is offline   Reply With Quote
Old 12-01-2005, 01:51 AM   #4
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
Are you planning on doing it yourself or having a contractor do it and just wanting to know a fair price?
If you want to figure how many square you have, you have to measure each plane (wall) of the house and how high it is. 100 square feet is 1 square so, if your house was a cube, 20 feet wide and 20 feet long and had no gable at all (hip roof), and the exterior walls were 9 feet high (as far as where the siding would cover, you would get 20 * 9 = 180 and that would be one wall. Since our cube house has 4 walls, we would say 180 * 4 = 720 or 7.2 square, which we would round up and buy 8 square.
Don't worry about subtracting for doors and windows, it gets used elsewhere. You do need to figure up how much J you'd need to wrap the doors and windows and how much starter strip (basically measure the perimeter of the house). For our cube house you'd need 4 outside corners. Your house might require more and also inside corners.
There's lots that's involved. If you're wanting a contractor price, go with the $350 per square and just figure how many square you have ($2,800 for the fictitious cube house).
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
vinly siding repairs burtco Building & Construction 3 01-01-2006 03:19 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
