Vinal Sidding Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2008, 06:11 PM   #1
Vinal sidding repair
My son broke a corner of our vinal sidding. I bought the house about 10 yrs ago and the previous owner put the sidding on. what can I do to fix so it matches the rest of the house?
couchguy is offline   Reply With Quote
Old 03-25-2008, 07:22 PM   #2
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
How old is the siding?
If it's not too old you may be able to can get a corner to match.Then it's a matter of replacement if you have some patience.It would be better if the Temp,around 70* or warmer.
If you can't find a replacement to match,than have some paint mixed to as close as you can or find someone in the field to do the repair.
Some I've seen covered in matching aluminum coil,but the results aren't always appealing.
I've also seen them repaired by cutting the nail fins off a newer piece and shoe-horning it over the damaged piece and then rivited on.
oldfrt is offline   Reply With Quote
Old 03-25-2008, 07:57 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated, it depends on the extent of the damage. Sometimes, areas can be repaired, sometimes, they need to be replaced.
I'm sorry to say, that it is time to replace your house....
- Build Well -
Old 03-26-2008, 12:20 AM   #4
What's "sidding"? Is that what you do on the couch?
Randell Tarin is offline   Reply With Quote
Old 03-26-2008, 06:08 AM   #5
The reality of it is, that you can purchase vinyl corner sections. The best place to try and match that up would be at a supply house that carries more than one brand of siding (in other words, not the Big Home Improvement Stores).
If the new replacement corner is "slightly" different looking than the older existing one, and you cannot seem to find a complete match anywhere, the old stand-by trick is to remove a matching corner from an inconspicuous area of the home, and install it in the conspicuous area. Then install the less-of-a-match area into the removed location.
All of the above would require a little more work, than a simple one hour DIY project, but the result won't be, that everytime you look at the unmatched conspicuous area, you cringe.
What ever you decide to do, or are able to do = Good Luck and work safely.
- Build Well -
Damaged electrical box - How to repair? theScud Electrical 17 06-24-2014 01:07 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 10:18 AM
LB Mower Repair Question kennykenny General DIY Discussions 1 09-23-2007 01:12 PM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 02:02 AM
