Very Strong Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 10:15 AM   #1
Very strong adhesive
A strong , fast drying adhesive to attach a plaster medallian to plasterboard ceiling ???
GUSGORT is offline   Reply With Quote
Old 03-30-2011, 01:43 PM   #2
Rewards Points: 5,336
A construction adhesive and some trim screws and caulk.
Ron
Old 03-30-2011, 03:15 PM   #3
Rewards Points: 282
and a 2x4 to hold it in place regardless of what you use and what the product says.
gorilla glue holds pretty much anything, but needs room to expand...
be careful if the plaster is powdery, you may need to drill/screw and patch.
jcrack_corn is offline   Reply With Quote
Old 03-30-2011, 04:11 PM   #4
Rewards Points: 1,216
PL Construction adhesive from Home Depot, good stuff.
COLDIRON is offline   Reply With Quote
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 01:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
