Vertical Rebar Support. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2007, 07:52 AM   #1
Vertical rebar support.
I am building a footing for a brick wall. The horizontal rebar is going in Ok supported by metal chairs. I want to have vertical rebar every four feet shaped like a "J" . The long side being 3' and the short side 1' wet set. I cannot think of a good way to keep the vertical rebar secure and plumb until the pour. Thanks for any suggestions.
jrepp is offline   Reply With Quote
Old 11-21-2007, 11:02 AM   #2
Rewards Points: 1,910
If this is the vertical rebar that will stick about 2 feet out of the footing, you just mark where it should go on the footing forms and then insert it at the marks right after the concrete is poured and screeded off. The concrete will hold it in place.
Old 11-21-2007, 12:21 PM   #3
Rewards Points: 5,336
Spot weld it to the horizontal bars.
Ron
Old 11-21-2007, 03:51 PM   #4
concretemasonry's Avatar
Rewards Points: 2,650
If the concrete will not hold it in place accurately enough for another concrete wall, your concrete is too wet to use anyway.
A 1' bend is really worthless when it comes to really developing the tensile strength of anything attached to it. For shear, you can get away with it.
concretemasonry is offline   Reply With Quote
Old 11-21-2007, 08:40 PM   #5
ICF Construction
Depending on your location wet setting may not be allowed. We use 4" PVC with holes drilled to support the top of the bar as well as make it OSHA compliant (Safety). You have to support the pipe every 12-15' with a temp. 2x4s to hold everything straight in a upside down 'Y' fashion. Found this works good and inspectors like it.
Chris
Chris Johnson is offline   Reply With Quote
Old 11-21-2007, 09:04 PM   #6
Are you building a little residential retaining wall in Podunk, USA or a commercial job in California or New York? - Judging by the bar dimensions for a brick wall (solid?) your job is not inspected or a critical situation.
Old 11-22-2007, 05:28 AM   #7
General Contractor
joasis's Avatar
An inspector will usually sign off if you have your locations for the rebar marked and the bars laid out. As the above post mentioned, the "hook" needs to be tighter. I rebar bender will make a perfect hook.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Replacing support beams Annimal76 Remodeling 1 09-10-2007 10:12 AM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 11:15 AM
Rebar Trees trout_baller Landscaping & Lawn Care 5 06-20-2007 05:39 PM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 08:55 AM
