Vertical Crack On Pour Foundation, Water Leaking - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 12:17 PM   #16
Rewards Points: 1,088
Originally Posted by baseballfan View Post
the crack is located right at the mid side of the house just below where the door is.
what u mean with grading on the outside and the water source is just when it rains and after winter when snow is melting.
Grading meaning how the dirt/ground slopes away from the house.
Water source meaning an open area for rain, or located near a gutter downspout.
Fixing leaks is usually a two prong approach.
1) Improve drainage on the outside, and
2) Patch cracks on the inside.
In fact, if you improve the drainage, that may get rid of leaks even with cracks left alone.
handy man88 is offline   Reply With Quote
Old 09-16-2008, 12:26 PM   #17
while the previous is always possible, you've got a better chance of seeing God show up to stop the water than remediating it thru only re-grading in my waterproofing experience,,, it MAY stop for a bit but the underground channels & rivulet passageways'll still be there still directing wtr into your very fine bsmt,,, don't forget wtr has all the time in the world while you are on a different timeline !
i've never seen improvements in grading resolve leaky basements,,, not arguing w/those who have - i just never saw it work permanently.
yesitsconcrete is offline   Reply With Quote
Old 09-16-2008, 12:53 PM   #18
That's why I said fixing leaks is usually a two prong approach.
Old 09-18-2008, 06:36 AM   #19
i can't disagree w/the aforementioned ' two prong approach ',,, however, its my belief exterior work's largely window-dressing,,, obviously less water reaching basement walls & footers is to any structure's advantage,,, bang-for-the-buck, regrading's h/o-diy work imn-s-hfo
Old 09-18-2008, 01:43 PM   #20
baseballfan's Avatar
hey guys ok i started digging the hole, and i find it a bit diffucult because i run into this stuff don't know if it's clay, it is really sticky and got this like light green kind of colour, more like the cement power mixture. i got as deep as 3 feet i can see the crack getting thinner. i guess it is better if i dig all the way down to the foundation footer right? or would it be enough if i start patching it now.
baseballfan is offline   Reply With Quote
Old 09-18-2008, 04:16 PM   #21
man that stuff is hard to dig out, it is like play doh, didn't expect to be this hard. if i have to dig the 8 feet it will be my work out for my next week. i hope 3 1/3 feet is enough please tell me so, lol
Old 09-19-2008, 08:25 AM   #22
hi somebody please, do u think it would be necesary to dig all the way down, the crack is getting smaller to a point where is hard to follow, or do i have to dig it all the way down.
Old 09-19-2008, 12:17 PM   #23
ok now i can't see the crack anymore, i cleaned it with a steel brush. i looked to see if it changed direcion like it did from the top but i don't know. i am at 5 1/2 feet down. what the hell
Old 09-19-2008, 04:13 PM   #24
ok guys i reached the footing of the foundation, but now i can't see where the crack is going. i can see it 16" from the footing, it doesn't seem to go all the way down to the footing, is that possible for the crack to stop like that?
Old 09-20-2008, 05:37 PM   #25
ok guys i am just posting this time to let you know i am done. i hope it is properly sealed. have to wait till it rains. thanks for your help
Old 09-20-2008, 08:44 PM   #26
Make sure that dirt is tamped down solid!
Old 09-20-2008, 09:18 PM   #27
dirt, that was mostly clay and it has gotten hard, this guy who does this told me that that i shouldn't use it or if i do i should mix it up with dirt or whatever it is u have to use to refill the hole. as u can tell i am really new at this it is my first time doing something of this caliber.
Old 09-20-2008, 09:34 PM   #28
concretemasonry's Avatar
Rewards Points: 2,626
Do not make the mistake of using "dirt" (whatever that is) or clay for most if the backfill. - That only increases the pressure against the wall.
You apparently do not have the drain tile that should have been there, so you will have to make sure you keep water away from the backfill since it will never be as dense as the native soil on the site. You can "cap" the backfill with clay IF you have good gutters and long downspout extensions.
By your description, you have a typical shrinkage crack that is very common in poured basements, especially if the contractor used very wet concrete to make the job easier.
concretemasonry is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 06:22 PM
