Vermiculite Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 02:27 PM   #1
Angry
Hi - just had an inspection done on a house today and the inspector found Vermiculite insulation poured in the attic that was not mentioned in the Truth in Housing along with the fiberglass also present. I've read up on the stuff and personally, I don't want to bother with it....and may not purchase the home as a result. Furthermore, the inspector, walked around in the attic (on the boards designated for walking - not the insulation) and came back down with dust on his clothes. I wanted to run out of the place!
Am I over-reacting???????
Thanks,
Budgie
Budgie123 is offline   Reply With Quote
Old 03-29-2010, 06:50 PM   #2
Rewards Points: 1,574
Never knew vermiculite was thought to be contaminated with asbestos, but it is:
http://dhs.wi.gov/eh/HlthHaz/fs/Vermiculite.htm
If you can, I wouldn't buy the property after reading that document.
bob22 is online now   Reply With Quote
Old 03-29-2010, 07:34 PM   #3
Remodeling Contractor
vermiculite may have asbestos in it, but not necessarily. As a rule and by code the process to deal with it is to not remove it, but to encapsulate it. However this may be difficult to do. If you do not need air sealing or more insulation there is not safety concern to leave it as is.
Old 03-29-2010, 07:56 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 624
Ayuh,... Sure are....Fiberglass isn't an issue,+ the percentage of Bad vermiculite is miniscule...
You'll have Better chances with Lightning, or the Lottery...
Bondo is online now   Reply With Quote
Old 04-03-2010, 12:25 AM   #5
I agree with Bob. Not all vermiculite has asbestos. Have it tested before considering walking away.
Alex Damgaard is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 10:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
