-   -   Vermiculite Insulation (http://www.diychatroom.com/f19/vermiculite-insulation-67875/)
Budgie123 03-29-2010 01:27 PM
Hi - just had an inspection done on a house today and the inspector found Vermiculite insulation poured in the attic that was not mentioned in the Truth in Housing along with the fiberglass also present. I've read up on the stuff and personally, I don't want to bother with it....and may not purchase the home as a result. Furthermore, the inspector, walked around in the attic (on the boards designated for walking - not the insulation) and came back down with dust on his clothes. I wanted to run out of the place! :furious:
Am I over-reacting??????? :huh:
Thanks,
Budgie
bob22 03-29-2010 05:50 PM
Never knew vermiculite was thought to be contaminated with asbestos, but it is:
http://dhs.wi.gov/eh/HlthHaz/fs/Vermiculite.htm
If you can, I wouldn't buy the property after reading that document.
Bob Mariani 03-29-2010 06:34 PM
vermiculite may have asbestos in it, but not necessarily. As a rule and by code the process to deal with it is to not remove it, but to encapsulate it. However this may be difficult to do. If you do not need air sealing or more insulation there is not safety concern to leave it as is.
Bondo 03-29-2010 06:56 PM
Ayuh,... Sure are....Fiberglass isn't an issue,+ the percentage of Bad vermiculite is miniscule...
You'll have Better chances with Lightning, or the Lottery...
Alex Damgaard 04-02-2010 11:25 PM
I agree with Bob. Not all vermiculite has asbestos. Have it tested before considering walking away.
