Old 09-23-2009, 08:37 PM   #1
Default Venting Shed Dormer
This kind of goes along with my other post. Doing a gut of a second floor, currently my roof has a ridge vent. I have a plan for the front of the house. There is eave attic storage space running the length of the house in the front and a kneewall separates it from the bedrooms. Basically in the front I will insulated and seal the unused attic eave space and where the knee wall begins I will run baffles from the kneewall up to the ridge vent. On the front of the house is soffits so I will install the soffit vents and the air will pull up like a chimney effect into the eave space and up the baffles to the ridge vent. My concern/dilemma is on the back side. I have a shed dormer and there are no soffits so not sure how to get the intake to make the ridge vent and venting work properly. How does this sound? Any Ideas?
Greg
gregt848 is offline   Reply With Quote
Old 10-01-2009, 12:19 AM   #2
Builder/Remodeler
mpepin's Avatar
Check out under-shingle venting. Its for areas where no soffit exists, it goes under the first coarse of roof shingles. Here's a link to one available product. http://www.dciproducts.com/html/smartvent.htm
Mike Pepin
www.alpinebayhomes.com
mpepin is offline   Reply With Quote
Old 10-01-2009, 01:31 AM   #3
Mike's smartvent is for 4/12 and more roof, if less than that, this is for a 3/12 rise per foot and more: http://www.cor-a-vent.com/in-vent.cfm. Is there any room for a vent above the gutter, on the fascia's top edge?
Be safe, Gary
GBR in WA is offline   Reply With Quote
Old 11-04-2009, 07:54 AM   #4
Thanks. Both of those would work. Regarding the space above the fascia, do you run a strip vent like under the soffit? What about snow and leaves do they get in? Tell me more, I may be able to do something like that too.
Old 11-04-2009, 11:25 AM   #5
Default Ridge Vent Roll
How about using a Ridge Vent Roll System? Trimline Building Products has a Ridge Vent Roll System that is very easy to install.
Ridge Vent Guy is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk here for a second about baffles. These are what we call baffles right here... Read More »
Spackling Roof Eaves
Spackling Roof Eaves by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk about spackling. Whenever you're spackling the exterior eaves on your house, you've got a couple of things you want to look... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The last full panel course is cut and installed. Vented top row flashing is then cut and installed as wall flashing. In snow climates rich foam... Read More »
Shed Dormer Framing Ohming Building & Construction 0 08-17-2009 01:45 PM
1920's Bungalow Shed Dormer A-Train Roofing 3 02-09-2009 05:00 PM
Shed Dormer on Bungalow? navi_jen Building & Construction 3 05-11-2008 12:36 AM
Venting of Cathedral Ceiling on Shed type roof sandyman720 Roofing 7 08-03-2007 12:27 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 09:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
