Old 08-10-2010, 10:36 AM   #1
venting range hood
My range hood is vented to the soffit on my roof eave, is this acceptable? or should it go through the roof?
rakuz66 is offline   Reply With Quote
Old 08-10-2010, 11:06 AM   #2
venting range hood
This should answer your question: http://www.easy2diy.com/cm/easy/diy_...ge_id=35743519
epson is offline   Reply With Quote
Old 08-10-2010, 11:11 AM   #3
venting range hood
I guess your saying it should go through the roof, not the soffit.
Old 08-10-2010, 11:15 AM   #4
venting range hood
yes...
Old 08-10-2010, 11:40 PM   #5
Moderator
venting range hood
"My range hood is vented to the soffit on my roof eave, is this acceptable?" --------- Possibly....
Needs to terminate outside, 3' minimum away from any openings into house (doors, windows, air supply, etc.) and property line. Requires a backdraft damper, very hard to do in a soffit application.
A good idea? NO- the soffit intake vents will bring the greasy/moist air into the attic to settle on the insulation. Check with your LOCAL B.D.
http://docs.google.com/viewer?a=v&q=...up65cYgFwMvULw
Be safe, Gary
Clothes taking longer to dry?
Old 08-12-2010, 05:53 PM   #6
venting range hood
My range hoods is vented to the soffit on my roof eave, is this acceptable? or should it go through the roof?
its fine
BronzeGenius is offline   Reply With Quote
Old 08-13-2010, 08:32 AM   #7
Not so new
12penny's Avatar
venting range hood
While it may be "fine", it certainly isnt the way I'd do it in my house or my customers houses. Its not just the grease but the humidity from the pot of pasta you're boiling.
In most cases I would opt to go thru the side of the house. The problem here is the need for a soffit to hide the ductwork.
Rooftop vents are reasonably priced and can be installed in less than an hour.
12penny is offline   Reply With Quote
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
range hood venting interested Building & Construction 5 12-10-2009 11:37 AM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
Range hood venting rdm440 Carpentry 15 06-25-2009 04:06 PM
Range Hood venting questions Crashless Remodeling 5 04-13-2008 10:30 PM
