Venting Dryer Through Cinder Block Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 12:38 PM   #1
Rewards Points: 156
Venting dryer through cinder block foundation wall
I want to vent my electric clothes dryer through a cinder block foundation wall. What's the best way/tool to cut a nice round hole in it? I thought about using a 4" hole bit but I don't think it will cut concrete very well -- plus burning up the teeth on a $30 bit kinda sucks. How do you guys do it?
jayp is offline   Reply With Quote
Old 04-07-2009, 12:52 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
this is the type of saw I like to use for cinder block. Then just pretty up the hole with trim.
Man of many hats
wrangler is offline   Reply With Quote
Old 04-07-2009, 02:40 PM   #3
Rewards Points: 156
hmmm
Is there some kind of a chisel or something to make it prettier? I mean, I'm all for busting a hole but I don't want some jagged-looking mess. I can always pack in new concrete around it after I'm done.
Old 04-07-2009, 03:04 PM   #4
You can use a 1/4" or 3/8" X 12" masonry drill bit to drill a series of holes in a 4" circle and then break out the middle with a hammer. Patch with morter after the vent pipe is installed.
Jim Hart is offline   Reply With Quote
Old 04-07-2009, 04:04 PM   #5
Rewards Points: 156
yes
I was thinking of that -- sounds like the perfect solution. Thanks!
Old 04-07-2009, 04:14 PM   #6
Nice!
And here's the best trim available for the job. (no cutting/nailing required)
woodlake is offline   Reply With Quote
Old 04-07-2009, 04:17 PM   #7
Household Handyman
Rewards Points: 1,408
I'm with Jim on that one. It's not that hard at all to drill, say a dozen or so holes and then knock out the chunk. I actually make my holes somewhat tight, pass through the aluminum sheet metal dryer vent and then use silicone caulk to seal it.
Old 04-07-2009, 05:39 PM   #8
Concrete & Masonry
Rewards Points: 548
Jay, how old are the block. If you have older block that are 3 core, your probaly going to hit a web, which is a pain. If newer 2 core, you should have about 6" to get your pipe thru without a web. I would recommend the mortar to patch it too, it will last forever, & nothing says "I don't care" like Great stuff.
jomama45 is offline   Reply With Quote
Old 04-07-2009, 07:00 PM   #9
Rewards Points: 156
haha
Totally... that's true. Yeah, I was planning on using cement patch just to give it a nice smooth look. The blocks are about 60 years old.
Old 04-07-2009, 07:05 PM   #10
Concrete & Masonry
Rewards Points: 548
Then they are probably 3 cores, which only have maybe 3-4" between the webs. You can usually verify by looking at the top of the foundation wall, assuming it's still open.
Old 04-08-2009, 06:18 AM   #11
Thumbs down
Jay, as stated above examine your block and find the holllow center dimension between webs if you can. I drill 2" central vac tube acceses in these frequently and charge by the hole due to risk of core bit damage and cost of future replacement bits.
Older 3" block that I have done has tighter webs and is much harder material than the current stuff,....not fun to do by hand.
I would rent a core bit and large hammer drill or find a plumber/ electrician /HVAC guy and let him have the headache for 15 minutes of his time (with the right tools) and your cash.
Is it too big a hole to pass code if you go through the rim joist instead?
Chemist1961 is offline   Reply With Quote
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 10:31 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 09:16 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 08:42 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 09:34 PM
