Venting Cathedral Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 12:50 AM   #1
Venting Cathedral ceiling
I have a cathedral ceiling 15 feet long on 24 inch centers, vented on the soffits and a ridge vent. I have I beams 11 7/8" deep.
Is an 1.5 inch of air space between roof sheating and the fiberglass the entire width between joist and the whole length of the roof enough?
I live in montreal, trying to get maximun insulation.
I was going to use Tyvek to create the air space then fiberglass then foil faced insulation board(Thermax).
Steve
dodge1930 is offline   Reply With Quote
Old 10-15-2010, 08:53 AM   #2
Rewards Points: 5,326
If you want maximum insulation, spray foam it.
Ron
Old 10-15-2010, 11:07 AM   #3
i wouldn't stress over this too much. just check with the insulation manufacture for their recommendation. i just did my cathedral ceiling and used Roxul. they recommend a minimum of 2" on flat or low pitched roofs, so 1.5" on your cathedral ceiling would probably be fine.
mklang is offline   Reply With Quote
venting a conventionally framed cathedral ceiling with a reverse gable 1960danm Roofing/Siding 0 03-27-2010 08:53 PM
cathedral ceiling vented or not in canada alberta boy Building & Construction 2 03-24-2010 07:32 AM
Insulatign Cathedral Ceiling Dutchman80 Building & Construction 5 01-07-2010 11:17 PM
Supporting a cathedral ceiling jmpn Carpentry 4 06-01-2009 11:29 AM
cathedral ceiling sweats bethmc Roofing/Siding 4 09-04-2008 08:25 PM
