Venting A Bathroom Exhasut Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 07:59 AM   #1
Rewards Points: 172
Venting a bathroom exhasut fan
Hello:
I am adding an exhasut fan to my second floor bathroom. I have acces to the attic and was wondering what the best option to vent the fan would be. I can exhaust it vertically through the roof which would be about 3 feet from the fan or I can exhaust it horizontally out the side of the house which would be a 12 foot run. What would be the best option?
I hesitate to exhasut out the roof jut for the leaking possibility...
thanks for any help!
zephed666 is offline   Reply With Quote
Old 04-21-2011, 09:13 AM   #2
Rewards Points: 5,336
Either case will work, but insulating the pipe might be easier through the roof. If you're putting it through an unheated space, the warm moisture laden air will condense in a cold environment if the pipe is left uninsulated
Ron
Old 04-21-2011, 06:01 PM   #3
Is there any code when it comes to placement of bathroom vents, cieling fan exhaust, toilet vent and sink vents? Is there like a "so many feet from the side of the roof" suggestion or code?
Avadon is offline   Reply With Quote
Old 04-22-2011, 11:56 AM   #4
mem
Rewards Points: 156
I'd be hesitant to put it thru the roof too. Run it horizontally with a slight pitch downward toward the outside. This will keep any condensation from running back inside thru the fan. Insulate as Ron said and you should be good. A 12 foot run with one elbow should not be a problem.
mem is offline   Reply With Quote
basement bathroom venting Bianco14 HVAC 5 02-16-2011 12:35 AM
Bathroom Venting on Septic System edro Plumbing 2 01-03-2011 07:41 AM
bathroom venting saul Kitchen & Bath Remodeling 6 11-02-2010 01:10 PM
Venting a bathroom Cossack Plumbing 10 06-27-2010 03:07 PM
Venting up vs out for bathroom, kitchen pcampbell HVAC 12 11-15-2008 10:02 AM
