#1 |
Vented Wooden Cover for Port Generator
I have installed a 7,000 watt portable generator on a 4X4' concrete slap. My operating Manuel says "Do not operate in rain" so I need to build a cover. My thoughts are just a pitched roof on a wood frame with ends and sides open. Need this venting process and access to gas tank and control panel. I can see in my minds eye what I want, somewhat like a dog house without the ends etc. My skills are limited and am looking for a plan. Thanks, Jim
#2 | |
Vented Wooden Cover for Port GeneratorQuote:
Well i don't have a plan for you,but make sure you protect the side with the generator from water,and be sure it's grounded,and don't touch it with wet hands while it's running,that's my .02 cents. |
#3 |
Do you have a few pictures of the pad, generator and site so we can see what you need? Generator enclosures around here are usually sealed, locked, and soundproofed.
#4 |
Ever built a deck? Framings going to be the same for the bottom part, except no floor joist.
4, post, 4 rim joist, then just add a roof. |
| Display Modes | |
| Generator & Interlock Kit – Float the Neutral? | Arnold Ziffel | Electrical | 12 | 01-13-2013 06:28 PM |
| Home Generator Confusion | MD_HomeOwner | Electrical | 11 | 12-23-2011 07:17 AM |
| Basement Decorative Wood Wall Cover popping up | tk3000 | Building & Construction | 8 | 10-29-2010 01:17 PM |
| Washer agitator/spinner turns one way, but not the other | IckesTheSane | Appliances | 5 | 01-10-2009 03:53 AM |
| Fascia cover filled with water/ice causing leaks | brianbh | Roofing/Siding | 10 | 02-11-2008 08:34 PM |
