Vented Skylight Over Staircase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-28-2013, 06:46 PM   #1
Not sure where to put this, so I'll start here. Mods, please move if appropriate!
I have a vented skylight over the staircase in my 1920's rowhome. I have no idea if it is orignal or not, but does seem to cause the stairwell to be either very hot or cold when the outside temp is above 90F or below 30F. Any thoughts on making this a little more energy efficient?
I did read here: http://forum.brownstoner.com/question/k-js3vuzblI=/is-old-skylight-over-common-hallway-meant-for-proper-ventilation-too
That these used to be covered with a piece of glass at ceiling height, is there any truth to this?
standmatt is offline   Reply With Quote
Old 04-28-2013, 10:49 PM   #2
Dave Sal's Avatar
Rewards Points: 632
My house was built in 1980 so I'm sure it's quite different but I have a skylight that I installed in about 1985. During the winter a cold draft could be felt under the skylight shaft. I decided to install a sheet of plexiglas at the bottom of the shaft at the level of the ceiling. The plexiglas is supported by a plastic or nylon grate. Works well and reduces the cold draft by about 90%-95%. Something like that might help you too. I posted a pic in a previous thread which you may be able to find by searching my posts. If not I'll post a pic tomorrow.
Dave Sal is offline   Reply With Quote
Old 04-29-2013, 08:08 PM   #3
Thanks Dave, that's a good idea. Do you remove it during the summer or leave it in place all year round?
Old 04-29-2013, 08:47 PM   #4
Dave Sal's Avatar
Rewards Points: 632
No, it's stays put all year long. Never had any problems with it and it keeps the conditioned air where it belongs, below the ceiling.
Old 06-25-2014, 05:43 PM   #5
Rewards Points: 12
I have a 1940s rowhouse with airshaft/skylight. There is indeed a rotating window at ceiling height. It does a reasonably good job of maintaining the temperature.
pac0571 is offline   Reply With Quote
The Following User Says Thank You to pac0571 For This Useful Post:
carpdad (06-27-2014)
Old 06-27-2014, 06:56 AM   #6
Rewards Points: 642
Love these reminders of simple, effective designs.
Can be made a bit better with 2 pane insulating glass for a new frame.
Is it possible for a close up of stop moldings/weather strip?
Thanks.
carpdad is offline   Reply With Quote
Old 11-07-2014, 12:14 PM   #7
Rewards Points: 12
I did weather strip it a few weeks ago. Does a good job of holding out the cold and noise.
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 05:47 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Air return through vented doors yam HVAC 7 08-22-2007 11:37 AM
New vented skylight in existing roof lightninrodman Remodeling 1 07-26-2007 06:47 AM
