Old 11-28-2010, 08:55 PM   #1
Vent well in concrete slab.
I have a crawl space vent that has a concrete slab in front of it. It is at or below grade so I need to put in some sort of vent well for it. Is it possible to chisel or remove a section of the slab to install a well or is there a product for these situations? Next to it you will see concrete steps that I plan to move over slightly as they are overlapping the vent byban inch or two. Help is greatly appreciated. Picture attached.
Atskodinski is offline   Reply With Quote
Old 11-28-2010, 09:09 PM   #2
Decided this picture might help too - gives a wider view.
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 10:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 11:57 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
Connect to cast vent in slab Joe F Plumbing 2 09-14-2008 06:33 AM
