Vent Pipes Through Metal Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 02:22 PM   #1
Rewards Points: 390
Now I did a search but did not find what I was looking for to help us.
Planning on running our sewer vent lines through our roof.
The roof is metal. The instructions I have found have been for a shingled roof.
So what do we do to keep the water out?
It is OSB board then tar paper then the metal roofing.
logluvr is offline   Reply With Quote
Old 10-15-2011, 02:40 PM   #2
Rewards Points: 6,652
It has already been discussed on here Correct Way to Flash a Vent Pipe With Metal Roof? If that is not enough, here are a couple of others: http://www.metalroofing.com/v2/forum...mCategoryID=18
http://www.terrylove.com/forums/show...ugh-metal-roof
Old 10-15-2011, 03:00 PM   #3
Rewards Points: 390
Thanks Greg.
That was what I had been looking for.
Old 10-17-2011, 09:51 PM   #4
If the vent terminates high enough and is big enough in diameter, functionally, it should be able to exit there...most people don't like the looks...not sure if it is to code or not.
Regards
Chantell Wilson
ChantellWilson is offline   Reply With Quote
Old 10-17-2011, 10:16 PM   #5
Rewards Points: 390
WTHeck?
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Not venting a metal roof. maestro Building & Construction 16 12-13-2011 02:31 AM
Shower roof vent problems silverbullit62 Roofing/Siding 3 02-24-2011 10:32 AM
Correct Way to Flash a Vent Pipe With Metal Roof? jonathan03 Roofing/Siding 4 06-22-2010 03:57 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
