Vent Free Insert With Dismantled Chimney? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2011, 05:19 PM   #1
vent free insert with dismantled chimney?
Hi all,
I have an old 1930s house with a small masonry fireplace (24inches wide). The chimney has been taken down below the roof, and the opening above the fireplace has been sealed by a piece of metal. I would like to put in a vent free insert but was told that the chimney needs to vent above the roof line for this... because the heat would get into the attic. I'm not sure if there is a way to vent the chimney out the side of the attic to avoid paying to rebuild the chimney? Also, I thought the point of these vent-free inserts was to avoid having to vent it... if anyone has any thoughts I would really appreciate it.
Thanks!
carolynaudet is offline   Reply With Quote
Is there a safe way to vent furnace exhaust with no chimney? FlyingHammer HVAC 3 02-17-2011 04:45 AM
Venting for Gas Fireplace Insert? MikeinBurien HVAC 7 11-18-2009 04:51 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Direct Vent or Free Gas Fireplace rocketdoctor HVAC 1 04-12-2009 06:47 AM
spacing soffit vent panels DangerMouse Building & Construction 2 10-29-2008 06:17 AM
