Veneer Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 11:47 AM   #1
veneer brick
Can I use OSI construction adhesive to install brick veneer on a door way arch verses using a motar on scratch coat. I was still going to use a wire mesh attatched to my wood frame work. Some one also mention thin set instead of an OSI adhesive.
IvanR is offline   Reply With Quote
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Replacing band joist behind brick veneer jzambon Building & Construction 0 03-09-2010 12:58 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
