Old 05-07-2009, 02:17 PM   #1
Vaulted Pine T&G Ceiling
Hello and thanks in advance for any help.
Please see attached photos:
Getting ready to install 8" Pine T&G boards to a vaulted ceiling. I've had the wood acclimating in the room for a couple weeks and I have a Porter Cable Finish Nailer to ease the installation. Boards are 12' and will be cut to a length of a little over 10'.
My main question involves the spacing of the nailing points. I'm going "with the rafters" on this one so I'm going to need to put down some 1x3's perpendicular to the rafters to provide mounting points for the boards. This will also help level things out. The ceiling has a slope to it and I've got the top and bottom mounting strips installed and level.
How many other mounting (furring) strips should I use. Each board will be roughly 10 ft in length (no staggering). Will five strips total be enough? That would give me roughly 24" spacing between the nailing points.
Thanks!
-Jim
Vaulted Pine T&G Ceiling-img_2161-1-.jpg   Vaulted Pine T&G Ceiling-img_2162-1-.jpg
Jambo Diego is offline   Reply With Quote
Old 05-08-2009, 06:59 AM   #2
If the boards are 3/4" thick, that should be fine. If they're 3/8" thick, I would set it so the boards were 16" on center.
Ron
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 10:25 AM
HELP! lighting question for vaulted ceiling pauls General Discussion 5 07-03-2010 05:53 PM
Running wire to a Ceiling Speaker (in vaulted ceiling) rgmetro Electrical 1 01-09-2008 11:27 AM
pine ceiling with T&G mark u Remodeling 17 09-27-2007 10:46 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
