Old 12-10-2007, 03:47 PM   #1
Vaulted ceiling insulation
New Construction. I have a vaulted ceiling that is 4.2/12 pitch. Is it ok to use blown in cellulose at this pitch or will the insulation eventually slide down towards the eves?
1K2GO is offline   Reply With Quote
Old 12-10-2007, 05:48 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You should consider batt insulation of spray foam.
- Build Well -
Old 12-10-2007, 06:38 PM   #3
Mod / ArchiBuilder
Cole's Avatar
I agree.
Your pitch is not steep, but I would over kill the area and go with spray foam!
Cole is offline   Reply With Quote
Old 12-10-2007, 06:43 PM   #4
General Contractor
joasis's Avatar
You can have it blown, and it won't slide. Foam of course is great, but if cost is a factor, go with cellulose. You can have the installer shoot it wet and it will "stick" and not go anywhere.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 07:51 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 06:30 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing 13 05-08-2006 10:55 AM
