Vaulted Ceiling Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 02:15 PM   #1
vaulted ceiling conversion
i have an old house and want to convert a standard 8 ft ceiling into an open ceiling with whats called a hot roof, what do i need to do?
doinit is offline   Reply With Quote
Old 02-27-2013, 02:35 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Welcome to DIYchatroom.
If your asking that question...then the best answer is to get out the phone book and start calling contractors to give you some quotes.
You will need to determine if the ceiling above is just a ceiling and that the roof is properly supported. If you don't know that yet, then the task is most likely beyond your capabilities. Call in an expert.
Other factors...thickness of roof joists.....spacing......sheathing....span....lots of little details.
ddawg16 is online now   Reply With Quote
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 09:25 AM
Vaulted ceiling moisture fride360 Building & Construction 7 05-06-2012 03:14 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Ceiling Fan and light switch conversion pmdockins Electrical 5 07-17-2011 09:52 PM
Crown moulding with a vaulted ceiling? cstrat Carpentry 34 06-17-2011 06:51 PM
