Hi
I have seen a video about " delta ms membrane " installed on the inside of a basement wall!!. would it work as well if I used 6mm plastic sheets to cover the block wall, then 2x4 the walls ,insulate and wrap with 6mm poly again , or am i causing vapour problems ???
I live in central Ontario, and remodeling a basement after having a french drain installed.
