Vapour Sealing An Electrical Box - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 01:55 PM   #1
Vapour sealing an electrical box
In order to save drywall work, i cut a hole in the drywall big enough to slip in an electrical box for a switch. How do i re-seal the vapour barrier???
batdude is offline   Reply With Quote
Old 01-09-2011, 05:05 PM   #2
Rewards Points: 154
you are going to have to remove the box and add a vapor barrier box and then tape that in
awdblazer is offline   Reply With Quote
Old 01-09-2011, 05:56 PM   #3
Yes I have the vapour barrier plastic boxes (should have mentioned that). But how to tape in? I am working only from the front in a hole no bigger than the box.
Old 01-10-2011, 07:30 AM   #4
Rewards Points: 154
just tape that box to the vapor barrier
or whats the problem you cant get to it? then your going to have to cut some drywall back and tape it
Old 01-10-2011, 06:30 PM   #5
Yes, its too hard to work from the front in a small hole. And I don't want to open any more drywall (hate doing drywall patching). So my new plan is to use silicon. Push the plastic box cover into the hole, push it back, put a bead of silicon around the flaps and then pull back to make contact with the vapour barrier. Can't think of any other way to do this.
Old 01-10-2011, 08:18 PM   #6
Rewards Points: 20
Acoustical sealant will give a much better and more permanent seal than silicone caulk.Caulking doesn't adhere well to poly. Just be careful with the sealant nozzle, that black stuff is nearly impossible to remove from where you don't want it.
daveb1 is offline   Reply With Quote
Old 01-11-2011, 03:31 AM   #7
Contractor - Renovations
fungku's Avatar
We call it black death.
If you get it anywhere it's not supposed to be, you're dead.
fungku is offline   Reply With Quote
Old 01-11-2011, 07:48 PM   #8
Thanks everyone. OK, I admit it. It was impossible to do and the "black death" comment really motivates me! I finally bit the bullet and cut back the drywall. Everything is in and properly done and was easy to do. No silicon or stupid shortcuts used.
But sadly, now I have to drywall and paint. I REALLY hate doing that. Makes such a mess.
Old 01-11-2011, 08:28 PM   #9
Rewards Points: 20
I find the black death comes off your hands if you have greasy pizza for lunch.
Old 01-11-2011, 08:32 PM   #10
Sometimes I call greasy pizza black death if you know what I mean.
Old 01-12-2011, 04:14 AM   #11
fungku's Avatar
At least you can feel proud that it's done proper.
Installing New Electrical Outlet - Vapour Barrier WhIsKeY Electrical 4 12-31-2009 12:08 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Air Sealing of Electrical Boxes on exterior walls PerpetuallyRepairing Electrical 6 07-14-2009 09:38 AM
Best technique for sealing electrical outlets/switches veesubotee HVAC 10 02-13-2009 10:05 PM
Sealing a vapour barrier in garage PatS General DIY Discussions 4 10-25-2008 09:51 AM
