Vapour Barrier Sealant Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 06:35 PM   #1
Solutions (handyman)
Rewards Points: 364
Vapour Barrier Sealant question
I know to put sealant (acoustic seal) between wood studs and vapour barrier, however when there is a seam should there be a bead of sealant between the stud and plastic then again between the two overlapping sheets of plastic?
I should know but have heard different opinions. Thanks.
Mark Harvey is offline   Reply With Quote
Old 01-31-2012, 07:21 PM   #2
Rewards Points: 13,960
Just tape the seams
Old 01-31-2012, 07:29 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
accoustical will give you a better seal where its a bitoumounous type sealant it will never truly dry. plus where your putting it on something that moves around a bit it will make it easier to use.
the problem with red tuck tape is that the glue on it dries out after 3 or 4 years. which is why its been banned for exterior use by the alberta siding association.. along with too many guys using it incorrectly.....
personally i like to use both to help keep the mess down.. use accoustical on the seam first then run a strip of tape down the edge just so it keeps the edge from flapping.. this way if you rub up against teh joint you doint get full of black death which wil never come out of your clothes
woodworkbykirk is offline   Reply With Quote
Vapor Barrier retrofit question bicycle-rider General DIY Discussions 3 02-05-2011 12:29 AM
Metal shed require vapour barrier? Mark Harvey Building & Construction 1 01-07-2011 06:25 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Carport to Garage: Fire barrier question Grommet Remodeling 2 03-28-2008 04:18 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
