Old 05-05-2008, 11:41 AM   #1
Question
vapour barrier in part of room?
We are redoing our baby's room and replacing some of the drywall in the closet (it had gotten some surface mildew from overuse of the humidifier, only on the exterior wall side). However, upon removing the drywall, we found that there was no vapour barrier (the house is approx. 55 years old).
We will replace the insulation, but the question is - do we put vapor barrier on the exterior wall side? In other words, will putting vapor barrier on only one small section of wall be helpful or will it lead to more problems? We certainly weren't planning on replacing all the drywall in the room.
Thanks for any advice...
bluejay is offline   Reply With Quote
Old 05-07-2008, 07:31 AM   #2
gravity always wins
Placing vapor retarder in part of a wall won't hurt. Keep the retarder towards the "warm in winter" side of the wall.
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
moisture behind vapour barrier piperboy General Discussion 9 10-21-2008 01:49 PM
Vapour Barrier Patching? mfleming Building & Construction 3 04-29-2008 01:00 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 11:13 AM
