Vapour Barrier-One Man Job? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 07:22 PM   #1
Vapour barrier-One man job?
Any tips on applying vapour barrier by yourself, or is it a job for two? I did my bathroom and made quite a mess with the acoutic sealant, hoping to avoid that with the rest of the house.
patrick.ogrady is offline   Reply With Quote
Old 08-27-2008, 09:02 PM   #2
Registered User
Termite's Avatar
There's no reason that you couldn't do it alone, but like a lot of tasks in building and remodeling, it is easier with some help. Personally, I'd get someone to lend a hand.
Old 08-28-2008, 06:55 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
It kind of depends on what you're using and where you're putting it. I've put up 6 mil poly on ceilings by myself. Start square along one wall and work the middle out keeping it taut. Then bring the sides after. Leave enough excess along the edges so that you can trim it back later.
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
vapour barrier in part of room? bluejay Building & Construction 1 05-07-2008 06:31 AM
Vapour Barrier Patching? mfleming Building & Construction 3 04-29-2008 12:00 PM
Double Vapour Barrier? canadaclub Building & Construction 4 01-14-2007 05:42 PM
Is this a double vapour barrier or not? KUIPORNG Remodeling 11 09-29-2006 10:13 AM
