Vapor Barriers In New England. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 07:39 PM   #1
Vapor Barriers in New England.
I have used drylock on my basement walls. Next step is framing before I do this, do I put up a vapor barrier. I have purchased thermal R-13 Insulation...reading all the articles I get mixed signals. Do I got Frame Insulation Barrier Sheetrock or Barreir Frame Insulation sheetrock or do i put vapor barrier on both sides? I assume not putting barrier on both sides because the insualtion has a plastic on one side. also which direction should the insulation face. thanks..
renzl24 is offline   Reply With Quote
Old 03-06-2011, 11:06 PM   #2
Rewards Points: 1,092
No vapor barrier in the basement. Two, anywhere, will trap moisture and you'll have a mold farm. Also, get better insulation that fiberglass batts; rock wool works well in basements, as they tend to be a bit humid. You can also use rigid foam before you stud it; search here, and buildingscience.com.
Post footing depth for New England? tpagel Building & Construction 4 07-31-2009 07:17 PM
New England costal house on pilings /frozen traps & cold floors snider Building & Construction 6 02-15-2009 07:51 AM
Hello From New England heavyworkman Introductions 2 12-13-2008 07:42 PM
Winterizing a house in New England almostdone Plumbing 5 10-17-2008 08:36 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
