Vapor Barrier, YAY Or NAY ??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 12:39 PM   #1
Rewards Points: 1,062
Question
vapor barrier, YAY or NAY ???
i have rarely been exposed to a more divided set of opinions than in regard to the use of 6-mil vapor barrier along with styrofoam scoreboard under concrete.
some say YES, some say NO.
should i or should i not, place a layer of vapor barrier under basement concrete in the mid-atlantic region ?
thanks !
Old 01-24-2008, 04:48 PM   #2
The plastic will keep the concrete from wicking moisture after it has cured. We always use it.
cnydave is offline   Reply With Quote
Old 01-24-2008, 06:20 PM   #3
Question
1. dirt
2. gravel
3. vapor barrier
4. foam board (1.5 in)
5. remash
6. concrete
in this order, is this correct ?
thx,
- a -
Old 01-25-2008, 05:06 PM   #4
you got it, gl
Old 01-25-2008, 08:01 PM   #5
Question
how bad is it if vapor barrier goes on top of the insulation instead of underneath ? i already have the insulation finagled in.
