Vapor Barrier Vs. Vapor Retarder - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 06:49 PM   #1
vapor barrier vs. vapor retarder
What's the difference, and which should I use? I'm Looking to put something between drywall and blown in cellulose. I live in SE Ohio. Thanks in advance.
mnstrohm is offline   Reply With Quote
Old 12-12-2010, 09:05 AM   #2
ccarlisle's Avatar
It's a question of degree of permeance; a 'vpour barrier' lets no vapour through it, a 'vapour retarder' does, to varying degrees. I also thin that nowadays we speak of vapour retarders more than vapour barriers, as we now know lots more about permeance of vapour through different materials. E.g: a coat of paint can be a vapour barrier of sorts...
A combination of vapour retarders can = a vapour barrier, too. In cold climates like yours, the idea is to control (perhaps even 'prevent') air from carrying moisture from warm to cold temperatures and thereby prevent excessive condensation. You do that, partially, by sealing gaps and by using vapour retarders on the warm side - in your climate.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-13-2010, 12:35 AM   #3
Rewards Points: 1,092
carlisle pretty well hit it. if curious, search on the greenbuildingadvisor.com for the ADA, and/or vapor barrier, etc. then read for a few hours and you'll know everything you need to. true vapor barriers are generally discouraged in all but zones 7 and 8 (very cold), esp if you air condition. one of the articles on the gba site had a story about a cat in southern(?) ohio that went boobs up because of using a vapor barrier in his new homes that had air conditioning. real bummer. j
Old 12-14-2010, 09:12 PM   #4
Registered User
Rewards Points: 4,924
http://www.cellulose.org/HomeOwners/...orBarriers.php
Gary
Old 12-14-2010, 10:01 PM   #5
also read up at buildingscience.com
http://www.buildingscience.com/docum...vapor-barriers
dreid47 is offline   Reply With Quote
