Vapor Barrier Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 06:18 PM   #16
con't
THanks MIchael, I guess I won't be putting up vapor barrier on the cold side of the floor.
Any other suggestions would be great.
And good luck Arky, it sounds like you are at the advantage of building it right in the first place.
C
colinp is offline   Reply With Quote
Old 11-08-2011, 10:24 PM   #17
Rewards Points: 502
Might want to look at a mobile home forum. houses on stilts are standard there.
IIRC, they have some special semi-breathable insulation they use for the undersides of trailers
forresth is offline   Reply With Quote
Tags
fiberglass , foam , insulation , moisture , vapor
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
