Vapor Barrier Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2014, 03:09 PM   #1
Rewards Points: 33
So I did some remodeling in my bathroom. I tore down the existing tile and greenboard above the bathtub and installed backerboard and new tile.
During all this, I tore down the vapor barrier on the exterior wall (I live in Michigan) because it had mold on it. Not wanting to tear down the entire wall to remove and replace the entire barrier, or attempt to patch such a large area, I redguarded the entire wall there once the backerboard was put up, and there is a slight overlap of redguard and vapor barrier.
The area I have a concern is there is a small area of no overlap below the tub lip. Here is an image of the area:
Now I'm starting to stress over whether or not I'm going to have a problem and would appreciate some feedback. Short of knocking down that entire wall, I'm not sure anything can be done at this point.
bigbopper180 is offline   Reply With Quote
Old 05-23-2014, 08:46 PM   #2
Rewards Points: 90
Don't stress. Small area, no worries. Ron
ront02769 is offline   Reply With Quote
Old 05-25-2014, 05:12 PM   #3
Registered User
Rewards Points: 4,888
Be sure the tub drain access hole at floor is fire-stopped to meet code minimum as this will also reduce air/moisture from condensing on the cavity insulation. The tub framing should have been blocked in the cavity from air/fire movement past the tub lip to above...
Gary
Old 06-30-2014, 02:22 PM   #4
Rewards Points: 33
I'd like to bump this one if it's OK. I don't know why, but it's been on my mind recently.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 02:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
