Vapor Barrier Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 02:10 PM   #16
Rewards Points: 502
Not familiar with the weeping-tile system - for internal damp-proofing of cellars we use the thick, dimpled polythene sheeting fixed to walls and floors (the stuff that looks like big bubble-wrap).
http://www.ebay.co.uk/sch/sis.html?_...r+%2F+basement
The idea is that the water runs down behind it and collects in a sump in the floor and is pumped out.
The studwork then goes against this, with the rigid board insulation between, then the v.b., and then the drywall. This system collects and then discharges penetrating ground water, and also prevents interstitial condensation in the insulation and studwork.
tony.g is offline   Reply With Quote
Old 03-28-2013, 04:39 PM   #17
Registered User
Rewards Points: 5,492
See "Exceptions"; http://publicecodes.cyberregs.com/ic...001_par003.htm
http://www.buildingscience.com/docum...ong-from-start
Wall #3; http://www.buildingscience.com/docum...study-analysis
Gary
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
