Vapor Barrier Plus Inside The Basement When Walls Are Sealed With A Penetrable Sealer Concrete Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2010, 05:57 PM   #1
vapor barrier plus inside the basement when walls are sealed with a penetrable sealer concrete walls
if the basement walls are sealed with a penetrateable sealer (inside the basement), do you still need a vapor barrier on the inside walls after one puts in the styrofoam insulated board?
myhouse2010 is offline   Reply With Quote
Old 10-18-2010, 12:35 AM   #2
Registered User
Rewards Points: 5,212
Not in FL or CA. http://www.buildingscience.com/docum...ent-insulation
http://www.buildingscience.com/docum...gs?full_view=1
Where are you?
Gary
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 01:44 PM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Frost at top of basement concrete walls dtabor Building & Construction 3 01-16-2009 09:00 PM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 09:10 AM
