Vapor Barrier Patching? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 02:59 PM   #1
vapor barrier patching?
When doing insulation with a paper vapor barrier do I need to worry about patching cuts and tears in the vapor barrier with tape. If so what type of tape should I use?
thanks
oregondiy is offline   Reply With Quote
Old 02-10-2009, 04:24 PM   #2
The first answer is it depends where you live and if it's in attic or walls. It varies by region and temp zone.
Chemist1961 is offline   Reply With Quote
Old 02-11-2009, 04:59 AM   #3
Rewards Points: 5,336
He might live in Oregon. Just a guess.
Ron
Old 02-11-2009, 05:21 AM   #4
Do you have a full or partial crawl space? You should keep your vapor barrier intact - you can use what is commonly called builders tape or sheathing tape - Lowes or HD....
Rivethead is offline   Reply With Quote
Old 02-11-2009, 06:52 PM   #5
Ok Ron I saw as I was signing off. It's like the other guy Vermont1 who's to know?.... I'M NOT REALLY A CHEMIST....Maybe he just want's to live in Oregon some day.
ODIY... The point I was making is some guys on here go nuts about even having a vapour barrier in the ceiling and I have come to learn it is a regional thing. Depending on your area's humidity, inland or not, etc the answer will be different. Where I live 6 mil poly is code for walls and ceiling....
Old 02-12-2009, 12:42 AM   #6
Yes, I am in Oregon.
I am isntalling the vapor barrier toward the warm side of the room.
Old 02-12-2009, 04:33 AM   #7
"Ok Ron I saw as I was signing off. It's like the other guy Vermont1 who's to know?.... "
My name is Bob.
Ron
Patching into existing drain with washing machine Kimball72 Plumbing 5 02-01-2009 04:28 PM
Patching Lawn, Squirrels, Birds and Headache BigJimmy Landscaping & Lawn Care 7 06-20-2008 11:29 PM
Prime before patching on drywall? DIYScott Remodeling 3 09-28-2007 09:19 PM
patching a rubber roof rade0041 Roofing/Siding 2 05-11-2007 10:17 PM
Wall Patching Shows Through After Painting wcw5961 Painting 5 11-16-2006 05:33 PM
