Vapor Barrier Over Garage - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 01:55 PM   #16
SteelToes's Avatar
Rewards Points: 150
Originally Posted by Ord View Post
I believe I need to put 5/8" drywall there in any case to meet the code here, no matter what kind of insulation I use.
For the XPS I meant two layers against the bottom of the joists and then the drywall below it - it just seemed a lot easier than cutting all those strips and foaming. There's probably good reasons not to do it.
You would need a 5" drywall nails to put that 5/8 drywall up + there is no 5" mud rings for the ceiling boxes ...etc
XPS foam sheets come pre scored 16" O.C...if the ceiling its framed right there is not much cutting to be done
SteelToes is offline   Reply With Quote
Old 05-10-2011, 02:00 PM   #17
Ord
Thanks, I see what you mean.
Ord is offline   Reply With Quote
Tags
garage , insulation , loft , vapor barrier
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
