Vapor Barrier For Outdoor Shed Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 11:38 AM   #1
Rewards Points: 1,062
Question
vapor barrier for outdoor shed concrete slab
yes or no ? it is 11x9, the footer is 2 ft deep and the slab will be about 4" thick. pros and cons of using plastic vapor barrier between the gravel and concrete ?
thanks
Old 08-31-2010, 01:47 PM   #2
Registered User
Rewards Points: 4,924
With that deep a footing and a gravel base, it sounds like in a cold climate. I would use one to stop the spring warming of the shed and contents from drawing the water vapor under the slab depositing on shed's contents to rust.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
amakarevic (08-31-2010)
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 10:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 11:57 AM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 07:13 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 11:37 AM
