To Vapor Barrier Or Not To Vapor Barrier, That Is The Question. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 12:17 PM   #1
To Vapor Barrier Or Not to Vapor Barrier, That Is The Question.
Hi,
I'm redoing a shower. I'm using 3/4" moisture resistant foam sheet insulation on the exterior block walls and furring strips over that (same way it was). Then cement board and a waterproof membrane. The problem I'm having is the foam that I took off had foil on both sides. I'm assuming that is a vapor barrier. I haven't seen any foam insulation that has foil. And the insulation companies have been useless in telling me if I need a vapor barrier or not. I'm not worrried about codes, just doing it correct. Do I need a vapot barrier? By the way the house is in central Florida. Thanks.
joegambler is offline   Reply With Quote
Old 09-18-2009, 12:47 PM   #2
Adding a vapor barrier on both sides of the cbu will create a moisture sandwich. install one or the other but not both. I am assuming this is an exterior wall.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 09-18-2009, 01:54 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
some types of foam bords need a foil barrier to eliminate off-gassing that will reduce the insulation value in the end.
Dick
concretemasonry is online now   Reply With Quote
Old 09-18-2009, 02:25 PM   #4
Mop in Hand
Hi,
I don't understand your reply. The foam I took out with foil on both sides was there originally from the builder. I'm not adding a vapor barrier to both sides of the cement board. The waterproofing membrane I'm using on top of the cbu is to waterproof the shower under the tiles. I just need to know if regular 3/4" foam board with no vapor barrier on the exterior wall is correct. Thanks.
Old 09-18-2009, 02:28 PM   #5
Concretemasonry
Hi,
From what I understand from your reply is that the foil doesn't necessarily make it a vapor barrier. O.K., I still need to know if no vapor barrier or yes. Thanks.
Old 09-18-2009, 10:40 PM   #6
No foil is needed. You do not want a foil/moisture barrier if you are using Redgard or the like on top of your cbu.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
