Old 10-04-2012, 06:23 AM   #1
Vapor barrier in multi-layered wall
I have been receiving different advice about where to replace a vapor barrier in a multi-layered wall.
I have a cottage in a cold climate, and because of an outside leak had to do a major repair of the outside wall and structural members. The composition of the wall (outside to inside) is: vinyl siding, chipboard, R20 insulation, chip board, plywood layer (recommended by an engineer to enhance strength of wall), drywall. Existing vapor barrier had been placed on inner chipboard (between chipboard and drywall). While this is on the "warm side" it is not directly atop insulation. Is this acceptable (the vapor barrier is just below the drywall as in more typical outside walls), or should it be next to the insulation, on the inner side (also as is typical of the usual outside wall)?
Any advice with an explanation would be most appreciated!
greyskies99 is offline   Reply With Quote
Old 10-04-2012, 10:33 AM   #2
Where you have it is fine.
mae-ling is offline   Reply With Quote
Old 10-04-2012, 10:53 AM   #3
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
That is a very strange sounding wall system.
Basically three layers of sheathing?
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
Tags
insulation, renovation, vapor barrier
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
the multi level sorta pony wall shlleys Carpentry 1 08-27-2011 01:48 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
