Vapor Barrier On Exterior Wall In Shower - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 04:00 PM   #1
Vapor barrier on exterior wall in shower
I gutted my bathroom to the studs and am now ready to put up the cement board. two walls are interior and one exterior. I put 4mil plastic on studs, over kraft faced insulation (put many vertical slits in the insulation) on the interior walls. my question is, what should I do with the one exterior wall? It has kraft faced insulation on it but do I do the same as what I did with the interior walls or leave just the insulation there and put on the cement board? the house is located in the northeast
Bob-1 is offline   Reply With Quote
Old 03-05-2011, 05:59 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would leave the insulation alone, don't install a moisture barrier at all. Then waterproof the inside of the board with a liquid waterproofing.
Otherwise slit the facing and install the moisture barrier.
XXX
Old 03-05-2011, 06:14 PM   #3
doesn't this violate the two layer barrier rule? I would have a vapor barrier on both sides of the cement board if I paint on the liquid barrier.
Old 03-05-2011, 06:40 PM   #4
Rewards Points: 212
i agree with bud. if it was my house i would leave it alone as long as there is no poly involved. or of you would sleep better at night i would remove it and put unfaced. then hang cement board and waterproof it with kerdi or some kind of liquid (redguard for example)
bluebird5 is offline   Reply With Quote
Old 03-05-2011, 06:56 PM   #5
ok. so cement board over the kraft faced insulation is adequate? If so, that is what I will do
Old 03-05-2011, 09:30 PM   #6
spray mold control behind insulation,or call a mold control place they should know what to do.Yellow pages here you come.
Stainless steel is offline   Reply With Quote
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
