Vapor Barrier In Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 11:26 AM   #1
Vapor Barrier in crawl space
I just purchased a home that is 15 years old and there was some mold on the joists that was remediaed before I bought it. Now the crawl space does not have a vapor barrier only gravel and dirt. It is vented. Is it too late to install a vapor barrier to prevent further mold and moisture damage?
Newgirl1956 is offline   Reply With Quote
Old 04-21-2011, 11:27 AM   #2
Residential Remodeler
Is there a vapor barrier under the gravel?
Is there insulation in the joist bays of the floor system? If so, does that have a kraft-facing (vapor barrier)?
CookeCarpentry is offline   Reply With Quote
Old 04-22-2011, 12:41 AM   #3
Registered User
Rewards Points: 5,216
Check under the gravel for the 6mil. plastic sheeting. If not present, I'd move the gravel to install one on the dirt. 15 year old house should have plywood or osb (vapor retarders; same perms as kraft paper facing) used as the decking. No need to add faced insulation.
And, welcome to the forum!
Gary
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Old Septic pipe flooding into crawl space ktipton Plumbing 2 04-14-2011 03:18 PM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 08:52 PM
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 06:09 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
