Vapor Barrier For A Concrete Pad - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2008, 06:56 PM   #1
Vapor barrier for a concrete pad
So here I go again about my little concrete pad.
Hopefully we'll pour next week and that will be the end of it.
So it's a 4'x10'x8" concrete pad for 3 PO Cluster boxes to be set on.
The ground is ready (8" of compact gravel) and the forms are in place but now I am reading about vapor barriers.
Do I need a vapor barrier at all for this?
Also, I cannot find 4" rebar chairs for the rebar mat. Would two 2" blocks placed on top of the other be ok for the purpose of elevating the rebar mat?
Thanks again.
grumpybear is offline   Reply With Quote
Old 06-28-2008, 07:51 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
You do not a vapor barrier for that type of slab.
Pieces of block or brick (concrete prefferd, clay is OK) would be fine to support the rebar.
Dick
concretemasonry is offline   Reply With Quote
Old 06-28-2008, 09:44 PM   #3
Thank you.
A few additional questions,
(1) Approximately how big should those small pieces of concrete blocks be?
(2) How far apart should they be spaced? My understanding, if using rebar chairs is that each rebar intersection should have a chair underneath. Should the same be applied when using blocks?
(3) I found plastic rebar chairs in the local home depot but they are 3" high. I know that the rebar mat should be 4" above ground since it's an 8" slab but is there any allowance to this? Can I use the 3" rebar chairs to save ourselves the headache of breaking up concrete blocks?
If it matters, the rebar mat is specified to #4 at 14" OC.
So there will be four 9'6" rebars spanning the 10ft length of the pad and eight 43" rebars the other direction
Old 06-29-2008, 06:00 AM   #4
(1) split 'em in 2
(2) you only need enuff to prevent sag out of spec - no particular amount/number.
(3) raise 'em up w/pieces of 2" conc block scrubbed into the base 1"
i will be so thrilled when this job's done !!!!!!!!!!!!!!!!!!!!!!!!!!!!
yesitsconcrete is offline   Reply With Quote
Old 06-29-2008, 12:58 PM   #5
Me too. I'll post pics of the most overthought, littlest concrete pad ever poured.
I do have to apologize as I tend to overthink things to the nth degree.
My poor son...
Old 06-29-2008, 11:10 PM   #6
Rewards Points: 150
My poor son...
hey do it right
comp is offline   Reply With Quote
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 12:21 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
