Vapor Barrier Behind Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 06:09 PM   #1
vapor barrier behind wall
Hi everyone; first time up.
I am about to help someone install a shower that was completely destroyed by incorrectly installed recessed soap and shampoo dispensers. When he ripped out the tile and backerboard, the moisture barrier is ripped. It also the only thing standing between the shower and some siding! That's plywood..nothing else..just a moisture barrier on some 2bys and the house. Since the barrier has a couple of rips, is there a way to patch it with some special bonding agent so that I can patch the holes? I realize the ideal thing would be to remove the siding and re-install a new barrier but if I can do a decent patch it would save us both a lot of work. Any ideas? Thanks in advance.
clemster is offline   Reply With Quote
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
