Vapor Barrier Basement Ceiling Edge? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 08:54 PM   #1
Vapor barrier basement ceiling edge?
Good day Folks. New here and really impressed with the forum and info.
I have a question. Our family room floor is 3' below grade and we are replacing the old ceiling and wall paneling with new drywall. Where the walls meet the ceiling we have installed new insulation. There is 6 mil vapor barrier on the walls. Do we need to place the VB to seal the upper corners (see pic). Thnxs.
road ruler is offline   Reply With Quote
Old 01-16-2013, 10:10 PM   #2
bbo
i replaced my insulation there with spray foam. closed cell.
more $$ but easier to vapor seal that way. the old insulation that was in there was borderline moldy if I remember right.
bbo is offline   Reply With Quote
Old 01-16-2013, 11:40 PM   #3
Rewards Points: 1,092
visqueen below grade? generally, that is not a good idea, and can be very bad. i would not use poly, unless code mandated or you are in a very cold spot. i think i'd either ditch the fg insulation and replace it w/ rigid foam, caulking or spray foaming around the edges, or put thinner rigid foam right over the fb and seal it as above. fg batts are generally pretty crappy insulation, but you did an excellent job installing them, which helps.
Basement ceiling question aggst1 Remodeling 9 05-07-2013 03:23 PM
Unfinished/Unheated Basement Ceiling Insulation mcusumano Insulation 4 08-31-2011 05:17 PM
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 06:58 PM
