Vapor Barrier In The Attic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 10:08 PM   #1
Rewards Points: 152
Vapor barrier in the attic
Was in the attic connecting bathroom fan to new roof vent (PO had it blowing directly into attic ) and noticed a couple things. Bear with me, I'm a hurting rookie at DIY.
Have a skylight in the bathroom, has a paint peeling problem since on the walls. Haven't tried repainting, just looked like it wasn't primed. Anyways, took a closer look today and there's plywood and 2x4's framing the skylight, don't see any vapor barrier. Is it possible it's between the drywall and plywood? Is the lack of barrier one of the causes of paint peeling?
Secondly, half my house is normal attic, half is cathedral ceiling. So in the attic is a wall that seperates the attic and the inside of the house with the higher ceilings. Again, no vapor barrier on this wall. Sort of guessing it needs it since it's laid down on all the ceiling drywall....?
Thanks in advance!
burnt03 is offline   Reply With Quote
Old 11-08-2010, 08:28 PM   #2
Rewards Points: 152
ttt plz
Old 02-19-2012, 09:54 AM   #3
Rewards Points: 152
ttt plz
Old 02-19-2012, 10:08 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
how old is the house. depending on the age there wouldnt have been vapor barrier if its old enough. there should be vapor barrier directly under the drywall on all surfaces which actual attic space is directly behind.. both in the bathroom ceiling and the skylight wells
woodworkbykirk is offline   Reply With Quote
Old 02-19-2012, 10:14 AM   #5
Rewards Points: 152
It was built in 1981.
There is vapor barrier on the ceilings (in the attic anyway).
If I removed the insulation, could I wrap and staple the plastic around the studs and then put the insulation back in?
If it's been like this since new, what's the worst that could happen if I left it as is?
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Attic fan options. P550 Electrical 6 08-22-2010 12:30 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
