Vapor Barrier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2007, 10:08 AM   #1
Rewards Points: 150
Vapor barrier?
my basement wall is poured concrete, exterior has 1 inch foam board insulation, interior is bare concrete. Do I put the vapor barrier, 6 mil plastic against the concrete wall then R-19 then sheetrock? or Insulation, vapor barrier then sheetrock? thanks
econdave is offline   Reply With Quote
Old 04-04-2007, 10:41 AM   #2
Rewards Points: 1,088
Generally speaking, it's insulation, vapor barrier, and then sheetrock. Imagine faced insulation, where the vapor barrier is stapled on the stud with insulation contacting the foundation.
handy man88 is offline   Reply With Quote
Old 04-04-2007, 11:37 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Econdave,
There has been much debate regarding the whole concept of vapor barriers (Not moisture barriers)... and their placement & their use in basements.
Here are links for you to read up on. These articles and other information may help you to understand and make a decision that is best for you:
http://en.wikipedia.org/wiki/Vapor_barrier
http://www.hammerzone.com/archives/l...ment_walls.htm
http://www.oldhouseweb.com/stories/Detailed/10362.shtml
http://www.buildingscienceconsulting...r_barriers.htm
http://www.naturalhandyman.com/iip/i...infinsul2.shtm
http://www.asktooltalk.com/home/qand...orbarriers.htm
http://www.eere.energy.gov/buildings...s/db/35017.pdf
http://www.diychatroom.com/newreply....wreply&p=39518
- Build Well -
Old 04-04-2007, 12:52 PM   #4
yummy mummy's Avatar
Rewards Points: 1,016
OH OH, Atlantic, that vapour barrier question again................
yummy mummy is offline   Reply With Quote
