Old 06-17-2009, 08:35 AM   #1
Vapor barier around IC box.. How to ??
I installed bazz bt 1200 IC boxes ( http://www.lightingexperts.ca/en/bul...lated-box.html ) in my kitchen ceiling which sits under a flat roof.
The ceiling is insulated and I now need to place a vapor barier over it, however I am not really sure what I am suppose to do around the IC boxes ?
Any tips would be appreciated? Thanx
the punisher is offline   Reply With Quote
Old 06-17-2009, 08:46 AM   #2
Dont know the product, but check instructions,I have seen similar wrapped with 6 mill poly or a preformed flex plastic weather proof box. Check instructions for HEAT build up and required breathing room....
Chemist1961 is offline   Reply With Quote
Old 06-17-2009, 09:05 AM   #3
The only instructions it has are on the box it self.. It shows that it has to sit under the vapor barrier but i don't see how the vapor barrier will stretch out that much.. I assume i am suppose to wrap it in a vapor barrier before i install it ...
Look at the attached pic and see what you make of it.. Thanx
Old 06-17-2009, 09:14 AM   #4
just called the company and they said i have to purchase a vapor barrier that goes around the box... Blue in color, then the plastic tapes to that.... weird but am gonna look into it i guess..
Old 06-18-2009, 09:54 PM   #5
The blue is the flex plastic box I mentuioned. You will seal the edges to other poly to form the vapour proof barrier. May also require acuostic type sealant or caulking at wire penetrations again depending on your code
