Vanity - Too Tight A Fit? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 12:45 PM   #1
Guest
Unhappy
Vanity - too tight a fit?
I have a 48" vanity that I'm trying to get into a just over 47.5" space. Has any body had any experience with removing the drywall on the sides of the vanity in order to allow it and the top (also 48") to fit? And then the drywall would come either down to the vanity top or I could use side / back back-splashes if required to clean up the look of where the drywall and vanity/vanity top meet.
Is it possible or am I asking for a whole lot of finishing trouble.
When the house was built they actually put in a 42" vanity and cut the vanity top to fit the current space and then added the back-splashes on top and wooded side pieces to close the gap between the vanity and the wall.
Would appreciate any experiences here.
9728 is offline   Reply With Quote
Old 12-08-2009, 12:56 PM   #2
Remodeling Contractor
what does the ends of this vanity look like. If this is a typical face frame cabinet you might be able to cut the cabinet and top down to fit. Or cut enough and replace the 1/2" drywall with 3/8" drywall. What is normally done would be to order the correct size vanity or buy a custom one to fit.
Old 12-12-2009, 04:11 PM   #3
Guest
Hi Bob.....the vanity section is 48" exactly and is basically a box - so no overhangs or anything......the top of the vanity is granite which right now does have a 0.5" overhang (49") on each side BUT the supplier will cut it to whatever size I want for no charge (it's an established family run company from another city that just opened a store here in Ottawa - I'm getting the vanity/top for a great price as part of the Grand Opening Sale to get people in the door). I do have the option of getting a 42" for the same price but would love to keep the extra cabinet space if doable.
I measured again and the front of the opening is 48" and then narrows to the back where it measures just shy of 47 3/4".
Old 12-12-2009, 04:32 PM   #4
Pat,
Sounds like the drywall finisher used a lot of mud in the corners which is not uncommon. There have been numerous occasions when we were installing baseboard or crown that we had to scrape the mud out of the corners to get the joints to fit properly. You could do the same in this situation then have the vendor cut the top 3/8" shorter than your opening and use side splashes or colored matched silicon.
It will still scratch up the wall so be prepared to do some drywall and paint touchup.
AtlRemodeling is offline   Reply With Quote
Old 12-12-2009, 05:27 PM   #5
is this a top you are having cut new if so he will come and make a tempale. if a piece you already own someone needs to make a template after vanity install either way
Old 12-13-2009, 06:13 AM   #6
What the others said, make a template from 1/4" underlayment or similar, from 2" strips glued with a hot glue gun. Transfer the profile to the underside of the top, and trim with a belt sander(since you only need to take off a small amount).
Old 12-13-2009, 07:29 AM   #7
shave the rock out. i installed cabinets for several cabinet shops here yrs ago. shave the studs a bit also if necessary. make sure vanity will slide into place, dont force it. have your top cut to fit and finish with your end splashes. dont cut your drywall out in front of vanity or higher than vanity.
good luck
kawendtco is offline   Reply With Quote
Old 12-14-2009, 08:42 AM   #8
Guest
Thanks to all for the help........sounds like I should be able to keep the 48" vanity......I'll let you know how it goes some time in January when I get around to finally redoing the bathroom.......
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Bathroom vanity? StevePax General DIY Discussions 5 11-08-2009 04:48 PM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 02:30 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
