Valley Cuts When Their Are Two Diff Pitches - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 03:37 AM   #1
valley cuts when their are two diff pitches
what does the valley cut on when theirs 12/12 pitch that meet 12/16
DywayneFERRELL is offline   Reply With Quote
Old 02-06-2012, 06:23 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
That's called a bastard because they're difficult to figure.
Bevel 40 (12/12 hv)(scribe) and miter (?) 12/16 h/v(saw table).
titanoman is offline   Reply With Quote
Old 02-06-2012, 07:48 AM   #3
I ask the impossible!
Rewards Points: 704
Isn't roof pitch usually rise/run and the rise is stated in terms of 12" of run, so 12/16 could be described as 9/12?
So I'm an engineer, I can do geometry, let's see if I can walk ya through this.
Starting with your 9/12 pitch, if you start from a point at the top, then come down 9 then across 12, then you come across perpindicular to that by 9 (since your 12/12 pitch roof would have come down 9, it comes across 9). This gets you to the point at the top of your valley.
Taking your two legs where you came across, using pythagorean theorm 9^2+12^2=x^2. X=15. This is the amount that your valley comes across horizontally after 9 of rise. So that would figure into how your ends will be cut.
Viewing from the top, to get your bevel angle, you're going across in the direction the 9/12 roof slopes by 12 and in the direction the 12/12 roof slopes by 9. So your angle should equal inverse tangent (9/12) = 36.9 degrees.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 02-06-2012, 09:01 AM   #4
Disabled wood vet
titanoman's Avatar
I rounded it off to 40.
Help with tricky valley wombosi Roofing/Siding 34 11-11-2011 08:22 AM
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 06:49 AM
I&W around pipes and valley metal fastening diyroofer Roofing/Siding 0 09-12-2011 05:39 PM
How to properly fill stress cuts in concrete before tiling? vseven Tiling, ceramics, marble 20 06-07-2011 08:53 PM
1000 bucks to fix the valley on my roof, is this ok? astronomer25 Roofing/Siding 3 09-14-2008 07:36 PM
