V Shaped Wall Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2006, 11:05 AM   #1
V shaped wall construction
I am building a lake cabin and the front of the cabin has a V shape wall, The nose of the wall extends 2' further out then the ends. The cabin is a one story with loft the front wall is 23 ft high with many windows, My question is: What is this type of wall called, and what are the structural benefits of this wall as opposed to a flat wall.
brosnt1 is offline   Reply With Quote
Old 01-24-2006, 01:26 PM   #2
Rewards Points: 77
V shaped works for me, you could call it Obtuse but the truth is you have two walls that meet at an obtuse angle. If you draw a line from one side wall to the other and then a line perpendicular from the point of the V back to that line you will have two triangles.
I know of no structural benifit gained by this it is for esthetics and to give persons inside viewing out a wider field of vision, so you could say it brings more of the outside in.
John
Zero Punch is offline   Reply With Quote
Old 01-24-2006, 07:13 PM   #3
renovations
Agreed, I don't know what it might be called, but it offers no structural benefits, merely architectural.
Bonus is offline   Reply With Quote
Old 02-08-2006, 03:00 PM   #4
Guy
I believe this is called a Prow Front. We see in often up here on Chalet styled homes where a view or more light is desired.
Guy is offline   Reply With Quote
Sauna Wall construction help Katherine Building & Construction 5 10-05-2016 06:42 PM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
