Using Ys For Piping In Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 07:59 AM   #1
Using Ys for piping in bathroom
On a related note to my other bathroom thread, is there any problem using Y piping in order to use one water and drain setup for two sinks?
Our current setup is one sink/vanity with one cold, one hot, and one drain. We are going to be installing a dual vanity. Although Id like to tap into the main water line to have seperate water sources and also a separate drain line for each sink, the location makes it unpractical and cost prohibitive (opening walls, floors, etc.)
So, aside from the possible low water pressure and slower drain time if we're both using the sinks at the same time, is there any problem with simply using Y piping under the sink to accomodate two sinks from one setup?
Thanks...
Wiscbldr is offline   Reply With Quote
Old 11-08-2011, 12:31 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
You should move this to the plumbing section
ddawg16 is online now   Reply With Quote
Bathroom to Laundry Room to Bathroom bcatanz10 Remodeling 2 10-10-2011 10:45 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 11:36 AM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 10:54 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
